Hello to all! I need your help, I need the Autodesk Softimage 2012 Subscription Advantage Pack Win x64 installer
xsisoft
Hello to all! I need your help, I need the Autodesk Softimage 2012 Subscription Advantage Pack Win x64 installer, I haven’t found it on the Internet, and I’ll appeal to the community, help me out!
Re: Hello to all! I need your help, I need the Autodesk Softimage 2012 Subscription Advantage Pack Win x64 installer
The Softimage 2012 Subscription Advantage Pack was never put out to the general public but only available to subscription owners at that time. All the enhancements made are available with the 2013 version. You will not found the SAP on the Autodesk website.
Can you still find any installer of Softimage on the website?
And a 2013 version would be best, as the 2012 version had a lot of issues with the disconnecting shadertrees if I recall correctly.
but good luck on the 'hunt'....
You can still found the installer using the search engine (don't use the drop down menu, Softimage is not listed). Search for Softimage 2013 or which ever version you desire (from version 2010 to 2015 sp2).
Link to 2013 SP1 below:
https://knowledge.autodesk.com/search-r ... rvice pack
For those interested, here is a link to the other versions that I could find on the Autodesk website. All version are full install so if you want the latest version of a specific year, download the most recent version with service pack except for the Hotfix version, those needs to be applied to the specific service pack of that version.
You will still have to deal with Autodesk Support for the license activation if you had a valid license (mileage will vary).
2015 SP2
https://knowledge.autodesk.com/search-r ... =softimage
2015 SP1
2014 SP2
2014 SP1
2013 SP1
2012 SP1
2011 SP2
2011 SP1 Hotfix2
2011 SP1 Hotfix 1
2011 SP1
2010 SP1
2015 SP2
2015 SP1
2014 SP2
2014 SP1
2013 SP1
2012 SP1
2011 SP2
2011 SP1 Hotfix2
2011 SP1 Hotfix 1
2011 SP1
2010 SP1
xsisoft
Thanks to all !
It is the softimage 2012 SAP - that is needed for- this compound
-AI Cut Geometry by Alpha- more here https://www.si-community.com/forum/v ... 879#p60879
Installed -AI Cut Geometry by Alpha- in softimage 2015 - WIN7x64 sp1, started testing -1 times worked (as in the attached video- ) from the alpha channel of the logo xsi, the geometry was obtained! Further the compound ceased to work correctly, makes geometry, but some kind of squares! tested on other versions of 2013, 2014, the result is the same.
The result is a need for version 2012 SAP - as in the demo video
Who does the compound work correctly, and with which version of the softimage & windows OS ?
3DMagic
- Skype: emiliano.grimaldi
xsisoft
not working links
Autodesk® Softimage® 2012 Service Pack 1
x32 http://download.autodesk.com/adsk/files ... 1537371052 = http://download.autodesk.com/errors/404.htm
x64 http://download.autodesk.com/adsk/files ... 1537371052 = http://download.autodesk.com/errors/404.htm
work only linux
- http://knowledge.autodesk.com/sites/def ... bit.tar.gz
not working links
Autodesk® Softimage® 2011 Service Pack 1
work only linux
other links work
softimage 2012 -is this is an anomaly
work only linux
not working links
work only linux
other links work
Nothing I can do about the broken link of ADSK unfortunately.
For 2011 load the SP2 version as the most recent that include all the previous service packs and hotfixes.
xsisoft
cut geo works here with 2015 latest, but only with alphas. With RGB it shows the blocks you mentioned. maybe you can convert your image to alpha transparency.
xsisoft
The problems were in a falling off texture projection, everything works in softimage 2015
xsisoft
