mAligner
jonmoore
Re: mAligner
Here you go:
https://d.pr/2pQjF5
I only installed it quite recently and I believe it's 1.8 (if memory serves right).
Enjoy.
jm
https://d.pr/2pQjF5
Enjoy.
jm
DG
Re: mAligner
If opened that file with notepad - <Description>mAligner v1.4. Nevertheless thank you!
jonmoore
Re: mAligner
Apologies.DG wrote: 02 Jul 2018, 06:33 If opened that file with notepad - <Description>mAligner v1.4. Nevertheless thank you!
Strange as I only downloaded it recently but I probably used the backup copy from Softimage Resources and it appears the link needs to be updated to the latest version.
Having said that, it appears to be working correctly with SI 2015 R2-SP2 (I just checked). I also just checked the mAligherPlugin.js myself and it's v1.5 (and shows up as v1.5 in the UI PPG), you can find it in the Transform menu.
I did a local search on Martin's blog and v1.6 appears to be the latest version with a blog post but unfortunately the file sharing service he used to host v1.6 is no longer functioning.
gaboraa
Re: mAligner
Here is the link to v1.6: https://app.box.com/s/hpt1gemr8ii3v1pqlkr15408203opioy
