Averages the positions of points with similar U or V coordinates. Usefull with TGen and cylindrical objects,
for making growing vines
NOTE: it relies on the correct (default) path for UV cluster. if it doesn't work, open the compound and set the UV path name (without the "self." at the begining)
video here:
http://vimeo.com/11844195
Moderator edit - embedded it using the new "vim" tags, remove if you don't want it embedded - HB
UV Thinner
UV Thinner
Averages the positions of points with similar U or V coordinates. Useful with TGen
and cylindrical objects, for making growing vines. Please see the vimeo video for more details.
local backup: UV Thinner.1.2.rar
author site: n/a / si-community thread
nassosy
UV Thinner
Re: UV Thinner
The video seems to be broken
nassosy
Re: UV Thinner
i'll be posting a fixed video as soon as possible.
(seems Vimeo doesn't like the Xvid codec)
RoN43
Re: UV Thinner
Nice compound! Thanks for sharing! Can you modify compound to trim, cut by UV. UV Cutter! and nice to do torque or rotation by UV!
RoN43
Re: UV Thinner
nassosy:
your compound use certain cls.AutomaticSamples.AutoUVTxtCoords.UVs, and i must explode compound and rename my Texture_Projection. if it possible do simpe method to use othe object with individual UVs?
gaboraa
Re: UV Thinner
Great compound! very useful indeed. Thanks
