Dynamic loading texture
anhungxadieu
Skype: nguyenvuducthuy
Post by anhungxadieu » 15 Mar 2018, 05:02
Hi, i want to animate a texture by loading its from an folder, for example in frame 0 i load texture "A" and in frame 10 i load texture "B" and so on ... Is there a way to do it in softimage?
caledonian_tartan
Re: Dynamic loading texture
Post by caledonian_tartan » 15 Mar 2018, 07:53
shure!
import as image sequence, drive time source.
check out this post:
https://www.si-community.com/forum/v ... =15&t=2786
SI 2015 @ WIN7-64
anhungxadieu
Post by anhungxadieu » 15 Mar 2018, 08:08
Thanks for the answer,
But it's only work with particle in that case source time can be drive by ice attribute
anhungxadieu
Post by anhungxadieu » 15 Mar 2018, 09:49
i found the way to do it simple create a script OP
	filePath = In_UpdateContext.filePath.Value
	obj = In_UpdateContext.obj.Value
	fileName = In_UpdateContext.num.Value
	file = filePath + "\\" + obj +"_"+ str(fileName).zfill(2) + ".png"
	sel = Application.ActiveSceneRoot.findChild(obj)
	exportClip = sel.Material.CurrentImageClip
	exportSource = exportClip.Source
	exportSource.Parameters("FileName").Value = file
