Hi There.
Does anyone know how to bake shapes to keyframes? I have some shapes driven by expressions, but I need to export it as FBX and the expressions don't translate of course.
Hence I need shape animation curves as baked keys. I can't see a way of plotting this but I'm sure there's a way. Does anyone know?
Baking out shapes?
Re: Baking out shapes?
The only way I can think of is connecting the shape weights to the X position of some nulls that get exported along in the fbx. Maybe someone else has a nicer solution.
Later in the other program these nulls could be connected directly, or their X animation curves copied over the shapes weights.
If the nulls are named exactly like the shapes are this could be scripted.
Pooby
Thanks so much for the reply..
After some fiddling, I found out that you can do it if you select the clip weight ( the one in the explorer) and then plot the marked value. I made a little script, so I could select them all in the mixer and do it in one fell swoop.
I always found it a little counterintuitive that although you can animate shapes in the shape mixer, its not REALLY there that its stored, its a kind of proxy for the Tracks. Anyway.. the above method works.
cheers
cheers
Ah nice, I forgot about that fbx keeps plotted animation on the shapes.
- Skype: ondraise
Plotting the clip weight! huh! Good one.
