prt reader in ice?
mattmos
prt reader in ice?
Post by mattmos » 17 Jan 2018, 17:23
Just wondering if there is any way to do this - have a prt sequence created from a bifrost sim, and wanted to bring it into ice to modify and render.
Re: prt reader in ice?
Post by rray » 17 Jan 2018, 17:52
Do a seach for "kies" in the resource section. It's for Softimage 2010, but might be worth a try. Other than that no idea.
mattmos
Post by mattmos » 17 Jan 2018, 18:05
Thanks for the reply, on linux as well just to complicate things unfortunately.
Post by rray » 17 Jan 2018, 18:14
It looks like here it was solved with some custom coding:
https://groups.google.com/forum/#!topic ... 4N5kdQjUFU
The icecache module mentioned is at the bottom of this page:
http://softimage.wiki.softimage.com/ind ... ile_Format
(wiki seems to be up again!)
also attached just in case..
sant0s
Post by sant0s » 19 Jan 2018, 06:05
If that does not work or is to slow, you can also go over houdini (when non-commercial it also works with the Apprentice version I think) , export as .bgeo (i think it was .bgeo or one of the other formats) and read in Softimage with emReader. :)
mattmos
Post by mattmos » 19 Jan 2018, 07:37
I couldn't get any of Eric's lovely tools to install on centos7 sadly :( But thanks for the suggestion. I wish they ran Houdini here too.
owei
Post by owei » 19 Jan 2018, 07:49
Hey Matt! I can convert it for you, if not to large ;)
mattmos
Post by mattmos » 22 Jan 2018, 12:35
Thanks for the offer Oliver! I think we're ok, moved up to 2018.2 and could get an alembic out which will do the job for now.
owei
Post by owei » 22 Jan 2018, 12:48
Great! I guess you mean 2015.2..2018.2 would be so sweet ;) Good luck!
mattmos
Post by mattmos » 22 Jan 2018, 12:55
Ah no, I did mean 2018.2 - went back into maya to mesh and export the alembic, which I couldn't do in 2016.5... Feels a bit dirty admitting that!
owei
Post by owei » 22 Jan 2018, 14:04
Ah sorry..on the Maya end..took that wrong...
