UV scale question
trea
UV scale question
Post by trea » 10 Dec 2017, 13:32
Hello
Does anyone know how to make planar UV projection retain the same scale for multiple polymeshes?
For example I am wanting to have a wall texture spanning multiple polymeshes, but when I use planar UV projection it causes the wall to be different depending on the polymesh bounding box. I'd like it so the projection is treating the UVs as a single polymesh.
Thank you.
Re: UV scale question
Post by rray » 10 Dec 2017, 14:31
Hi trea,
you can match the scale of the green texture support objects. Select all except the biggest one, transform>match scaling, then pick the biggest one.
Setting the selection filter to "teture control object" can help you with the picking.
Only idea I have right now, there are probably some other options
trea
Post by trea » 11 Dec 2017, 00:50
It works, thank you!
Edit: Thank you FXDude, that is exactly what I was looking for.
Post by FXDude » 12 Dec 2017, 02:59
I'm not sure if it also applies to what you're after,
but you can also share a single texture projection or support across a number of objects ::
Select items, and ...
Get > Property > Texture Projection > Connect to Support (or to Projection)
OR if you get a new projection on a group, they will all share the same support
