turbulize mesh - via weight maps ?
thorsnuts
Post by thorsnuts » 27 Oct 2017, 13:53
Hello,
I'm trying to achieve a look using turbulize mesh, but I'd like to break it up using weight maps - So certain areas are effected and others not.
Is this possible?
thank you
Re: turbulize mesh - via weight maps ?
Post by rray » 27 Oct 2017, 14:01
you can use a scalar to 3d vector to convert your weightmap to the variance
thorsnuts
Post by thorsnuts » 27 Oct 2017, 14:45
Hello,
Thank you for the time. So I ran into a problem where the Value of the Get Weight map node is Black and doesn't plug into the Scalar node
thorsnuts
Post by thorsnuts » 27 Oct 2017, 14:46
Another question would be how to control the Variance number once it's pluged in?
Post by rray » 27 Oct 2017, 15:00
you'll have to double click the blue weightmap node, then select the "weights" parameter with the explorer.
If you want to modify the strength, you can put a multiply node between "scalar to 3d vector" and "turbulize mesh", and edit the multiplication vector
thorsnuts
Post by thorsnuts » 27 Oct 2017, 15:14
Awesome... thanks!!!.
Works lovely
Thanks for the time
