Help with simple script
gfeather
Post by gfeather » 27 Sep 2017, 20:00
I am not a scripter at all. I am using softimage XSI 7.01, and all I really need it to do, is read the position and rotation information off a selected null or object on each frame and output that to a text file that looks like the image attatched.
It looks like there is 1 tab space between each parameter.
I am using this to load it back into tracking software and this is the format it uses.
Re: Help with simple script
Post by rray » 27 Sep 2017, 23:06
This script logs the data to the script output. There will be some //INFO like characters at the left that you would have to delete...
(script editor must be set to jscript to run this)
var sel=Selection(0);
var space="     ";
var frames=20;
for(var n=1; n<frames; n++)
	logmessage(n+space+
			sel.kinematics.local.posx.value(n)+space+
			sel.kinematics.local.posy.value(n)+space+
			sel.kinematics.local.posz.value(n)+space+
			sel.kinematics.local.roty.value(n)+space+
			sel.kinematics.local.rotx.value(n)+space+
			sel.kinematics.local.rotz.value(n)+space
myara
Post by myara » 28 Sep 2017, 03:18
Nice rray! I didn't know you could get a frame position with that. I always used GetValue :P
I modified that code to round those values to 3 decimals, and write it into a TXT file:
//JScript
var space = "     "
var startFrame = 1
var endFrame = 20
var roundDecimals = 3
var filePath = "D:\\test.txt"
var fso = new ActiveXObject( "Scripting.FileSystemObject" );
var txt = fso.OpenTextFile( filePath, 2, true )
for(var n=startFrame; n<endFrame+1; n++)
	txt.WriteLine( n+space+
			sel.kinematics.local.posx.value(n).toFixed(roundDecimals) +space+
			sel.kinematics.local.posy.value(n).toFixed(roundDecimals) +space+
			sel.kinematics.local.posz.value(n).toFixed(roundDecimals) +space+
			sel.kinematics.local.roty.value(n).toFixed(roundDecimals) +space+
			sel.kinematics.local.rotx.value(n).toFixed(roundDecimals) +space+
			sel.kinematics.local.rotz.value(n).toFixed(roundDecimals) +space
txt.Close();
And a few notes:
In my modified version I separated the variables you can edit to the top, and the code to the bottom.
Be sure to run this in a JScript tab (not VBscript nor Python).
If you want global values, replace "local" with "global.
When you specify a file path, use \\ instead of \. (ex: D:\test.txt is wrong, D:\\test.txt is correct)
M.Yara
Post by rray » 28 Sep 2017, 12:56
Hehe didn't know either, just discovered by accident.. thought it might be worth a try before looking up the GetValue syntax with frames. :D
gfeather
Post by gfeather » 28 Sep 2017, 16:45
Thank you so much, that does exactly what I needed!
