Was looking for information on Ice particle velocity
should be information on this old wiki page
http://softimage.wiki.softimage.com/xsi ... eSpeed.htm
but it is not there anymore
Anywhere I can read that old softimage wiki page or some Ice related documentation?
thx in advance
Cyborgen
wiki info on Ice
Re: wiki info on Ice
http://docs.autodesk.com/SI/2015/ENU/#! ... eSpeed.htm
It would seem Autodesk finally killed off the wiki without further notification (after explicitly stating they would keep it open)
mc_axe
Wiki had a bright future aswell
Great company. Case of right hand not knowing what the left is doing. At a minimum the right hand should have known that this is the case by now .. so..
better download the offline docs
FYI - the downloadable version of the docs can be found on this page...
Case of us still trusting anything Autodesk claims...rray wrote:Great company. Case of right hand not knowing what the left is doing. At a minimum the right hand should have known that this is the case by now .. so..
The wiki just has a copy of the official doc. The same one you get by pressing F1 in Softimage.
Autodesk should have deleted it from the wiki so that google doesn't keep indexing it and have it come up above the real doc. I guess google gives wikis higher page ranks.
Looks like now the official docs were deleted instead, can't reach them using the Softimage help menu at least
Edit: seems to have been a temporary glitch. Just checked both the docs and the sdk-docs appeared to be online again... (no idea how long this will last...)
But downloading the offline-docs would be advisable to anyone who hasn't done so already: https://knowledge.autodesk.com/search-r ... ation.html
Ah I see, its url was changed. That break them if you want to access them work from inside XSI ... not a big issue anyway since offline help works just as well now.
