Displacement Map To Create Sub-Polygons ?
Frank1000
Skype: the2he
Post by Frank1000 » 22 May 2017, 20:55
is it possible to refine the actual polygon object with sub-polygons by applying a displacement map ?
I found Model/Modify/Deform/Push, but didn't see how to apply the image to it ... probably it needs to be a weightmap or fiddled in the material editor.
Re: Displacement Map To Create Sub-Polygons ?
Post by rray » 22 May 2017, 21:14
Images and animations work fine too when you create a texture map on your mesh (get->property->texture map)
After that you can pick the clip using the plug button
mc_axe
Post by mc_axe » 22 May 2017, 22:00
Was always wandering aswell, how to get the result of a displacement, nice workaround.
Frank1000
Skype: the2he
Post by Frank1000 » 23 May 2017, 10:56
thx rray :)
