I could use some user input right about now
But this only applies to the "subsilver2" style
This is the way our links are denoted at the moment...
Personally I find this almost indistinguishable from the normal text, making it not very obvious where one should click...
So I want to change the link color.
This would become the way our links are denoted, which by the way is rgb(255,64,64) or hex "#ff4040"
And while it obviously clashes with the rest of the color scheme (but that's the whole point), do you think this would work or could one of you artists (which I most definitively am not) come up with a reasonable alternative, that stands out while still fitting into the general color scheme of "subsilver2"?
Thanks in advance...
