hi guys..
Someone here have tried "TX_Manager" by Vincent Ullmann?
http://www.vincentullmann.com/tools.html
I just can't make it work. I tried to contact the dev, but he never reply me.(4months ago).
Someone else is trying to help me, with no luck...
Using Win7 64, Softimage 2015 SP2.
Can someone here check the code? It's a very easy to use plugin, and applying the "maketx.bat" manually it's a pain in the a.. when you have a lot to handle in your scene.
Look at the attachment, that's the kind of error i get.
thanks in adv,
TX_manager
Tenshi
TX_manager
Tenshi
Re: TX_manager
no one?
I install the plugin in the Factory root.
Have the texture inside "Pictures" project folders, and in other non-project folder, and with both i received this bad code in script editor.:
Anybody knows what's that?
# File "<Script Block 2>", line 380, in vu_txManager_PPG_createTx_OnClicked
# makeTXbatch.write(content)
# UnicodeEncodeError: 'ascii' codec can't encode character u'\xe1' in position 156: ordinal not in range(128)
# - [line 379 in C:\Program Files\Autodesk\Softimage 2015 SP2\Application\Plugins\txManager_v06.py]
# ERROR : Property Page Script Logic Error (Python ActiveX Scripting Engine)
# ERROR : [377]
# ERROR : [378] content += "ECHO Y | DEL " + maketx_batch + "\n"
# ERROR : >[379] makeTXbatch = open(maketx_batch, "w")
# ERROR : [380] makeTXbatch.write(content)
# ERROR : [381] makeTXbatch.close()
# ERROR : [382] os.startfile(maketx_batch)
