deform by point
anhungxadieu
Skype: nguyenvuducthuy
deform by point
Post by anhungxadieu » 14 Nov 2016, 10:37
hi there,
i have a point like this image anyway for me to deform them mesh with that point cloud?
thank you!
Pooby
Re: deform by point
Post by Pooby » 14 Nov 2016, 16:07
Yes, but how do you wish it to be deformed?
As if its an envelope?
anhungxadieu
Re: deform by point
Post by anhungxadieu » 14 Nov 2016, 16:46
well, as you can see on a last image i want every point on the point cloud will move every point on the mesh, because i create that mesh by the point cloud and it will math the position and id, the problem i have right now after i merge that mesh with the other mesh and weld it together (in case i merge the mouth and the head) it change the topology and also change the number of point in so it doesn't math with the point cloud anymore ... anyway to filter only some point on the point cloud the deform the mesh (in case i only want to deform the mouth after i merge it)
here i up a movie i hope you can understand what i want to do
thanks!
https://drive.google.com/file/d/0Bz5Tvz ... sp=sharing
Pooby
Re: deform by point
Post by Pooby » 14 Nov 2016, 19:13
You have to 'get closest' when you don't have topological matches
anhungxadieu
Re: deform by point
Post by anhungxadieu » 15 Nov 2016, 11:12
yes, it's done :) thanks, but it is a only way?
