Convert Instance to model / geometry
tarkovsky
Post by tarkovsky » 01 Nov 2016, 15:26
Hi all.
I need to export a file for someone else to use in Sketchup. I used a lot of instanced geometry (no ICE).
Found various scripts for converting the instances to models, but none seem to work on 2015.
Skype: ondraise
Re: Convert Instance to model / geometry
Post by Draise » 01 Nov 2016, 15:46
I think freezing them turns them to normal objects.
gaboraa
Post by gaboraa » 01 Nov 2016, 16:28
below script seems to work for me
si = Application
sel = si.Selection
count = si.Selection.Count
selection = [sel[i] for i in range(count) if str(si.ClassName(sel[i])) == 'Model' and sel[i].ModelKind == 2]
for i in selection:
    d = si.Duplicate("B:"+str(i.InstanceMaster))
    si.MatchTransform(d, i)
    if i.Parent.Name != si.ActiveProject.ActiveScene.Root.Name:
        si.ParentObj(i.Parent, d)
    si.DeleteObj(i)
tarkovsky
Post by tarkovsky » 02 Nov 2016, 14:20
gaboraa wrote:below script seems to work for me
si = Application
sel = si.Selection
for i in selection:
    si.DeleteObj(i)
Fantastic. Thought I tried that one - dunno why it didn't work the first time. Thanks!
@Draise: No the Instances don't become models by freezing them :)
Skype: ondraise
Post by Draise » 02 Nov 2016, 15:47
Ah. I was thinking clones. x_x
