ET_ControlSetup v1.3
ET_ControlSetupAuthor: Eric Thivierge
This plug-in imports controllers and constrains the selected objects to the imported copy of the control. You have the option to constrain by Position, Orientation, Scale, and Pose. You can optionally select the »Import« button and have the control imported and placed at world 0.
This plug-in is meant to be expandable by the end user. Inside the add-on's »Data« folder there is a »Models« and »Images« folder. Users can export their own controls to this »Models« folder by putting the control under a model null and going to File > Export > Model. You can additionally create an icon for it by going to the »Images« folder and editing the *.psd file and saving it in the same naming convention as per the supplied controls.
Video available on vimeo (also embedded in author link).
local backup: ET_ControlSetup_1.3.xsiaddon
New plugins, tools etc.
Post by EricTRocks » 04 May 2010, 03:14
This plug-in imports controllers and constrains the selected objects to the imported copy of the control. You have the option to constrain by Position, Orientation, Scale, and Pose. You can optionally select the “Import” button and have the control imported and placed at world 0.
This plug-in is meant to be expandable by the end user. Inside the add-on’s “Data” folder there is a “Models” and “Images” folder. Users can export their own controls to this “Models” folder by putting the control under a model null and going to File > Export > Model. You can additionally create an icon for it by going to the “Images” folder and editing the *.psd file and saving it in the same naming convention as per the supplied controls.
http://www.ethivierge.com/scripting/et_ ... etup-v1-3/
Video:
Cheers,
Eric T.
Eric Thivierge
Re: ET_ControlSetup v1.3
Post by Hirazi Blue » 04 May 2010, 07:08
Hi, you probably hadn't noticed, but I did already start a thread for the previous version (1.25).
I'll close that one now, letting everything play out here...
BUT: more importantly: CHECK YOUR LINKS AND USE THE URL TAGS!!! X(
The link in your post could not be resolved, so I had to recheck the link to find out where it should go... ;)
Post by EricTRocks » 04 May 2010, 13:00
Hi Hirazi,
Thanks for the info. I'll be sure to double check the links next post.
Cheers,
Eric T.
Eric Thivierge
