?proportional editing of multiple curves?
wesserbro
Post by wesserbro » 11 Sep 2016, 12:07
Hi, All! I have a curve network. These curves just describe human face basic lines. They are not always connected and definitely do not form proper cage for "curve net" operator, and can be filled with surfaces only with step by step 'four-sided' operation. I'm saying all this because i cant just make single nurbs surface from this curve network and use proportional modeling.
So, is there an easy way to proportionally edit this curves? I can only think of creating mesh with vertices at every curve point and then bind curve points to vertices of that mesh )) to long and tedious (
Re: ?proportional editing of multiple curves?
Post by rray » 11 Sep 2016, 13:03
You coud try this addon: http://www.keyvis.at/cg-tools/tools-for ... rve-tools/
and then do attach curves to create 1 curve object with subcurves, then do the tweaks and then use "extract all subcurves"
wesserbro
Post by wesserbro » 11 Sep 2016, 13:15
i'v joined them with plugin, but proportional editing still cant be applied to curves (or i'm missing something?)
P.S. My bad, its working, just didnt see distance limit was 0 ))
Thanks, rray!
