How do I rotate objects?
Post by rray » 13 Aug 2016, 19:07
I still haven't figured out how to rotate objects properly in the viewport :))
when I rotate something with the usual transform tool, it goes to from 0 up to 90 degrees without problem, but then when I rotate further, it jumps to -90 degrees rotation an then goes back to 0. I can't go over 90 unless I do a sequence of individual transforms (I'm using spherical interaction style, with linear I don't have that problem)
-rr
Re: How do I rotate objects?
Post by rray » 14 Aug 2016, 00:24
Ok found out what it was:
When using using spherical interaction style (means move mouse pointer in circles around the object to rotate it), the SRT Increments speed for rotate shouldn't be lower than 1.
