Redshift 2.0
Redshift 2.0
Post by Hirazi Blue » 04 Jul 2016, 15:31
According to fxguide the second incarnation of Redshift now has been officially released...
Redshift has released a new version of their GPU-accelerated biased renderer which runs on NVIDIA GPUs. New features include initial Open VDB support, new BRDFs (GGX and Beckmann/CookTorrance), new and improved SSS models, a new and more intuitive PBR-based Redshift Material, and more.
The new version also debuts integration with 3ds Max, with Houdini and Cinema 4D support coming later this year.
Key Redshift 2.0 features
  • Volumetrics (OpenVDB) – Render clouds, smoke, fire and other volumetric effects with production-quality results (initial support for OpenVDB volume containers).
  • Nested dielectrics – Accurately simulate the intersection of transparent materials with realistic results and no visual artifacts.
  • New BRDFS and linear glossiness response – Model a wider variety of metallic and reflective surfaces via the latest and greatest in surface shading technologies (GGX and Beckmann/CookTorrance BRDFs).
  • New SSS models and single scattering – Attain more realistic results with support for improved subsurface scattering models and single-scattering.
  • Redshift Material – Utilize a more intuitive, PBR-based main material, featuring effects such as dispersion/chromatic aberration.
  • Multiple dome lights – Combine multiple dome lights to create more compelling lighting.
    alSurface support – Access full support for the Arnold shader without having to port settings.
  • Baking – Save considerable amounts of rendering time with baking for lighting and AOVs.
New release sale Redshift is offering 20% off new Redshift licenses for two weeks from 5th July, 2016.
(All quoted from here)
mc_axe
Re: Redshift 2.0
Post by mc_axe » 26 Jul 2016, 12:40
Did anyone tested baking feature yet?
Is it only to improove render times with light baking?
or you can save for example an AO render to UV space?
julius
Re: Redshift 2.0
Post by julius » 26 Jul 2016, 19:29
I tested : "baking" is tuned to improove render times with light baking.
But Redshift works with rendermap, so you can save an AO render to uv space too.
mattmos
Re: Redshift 2.0
Post by mattmos » 26 Jul 2016, 19:56
Baking works well, saved my skin on a recent project where we were camera projecting background textures, but then had to animate a moving camera past where the projection ended - baked ti out, bit of photoshop to fix the missing areas and worked a treat.
mc_axe
Re: Redshift 2.0
Post by mc_axe » 26 Jul 2016, 20:07
julius wrote:I tested : "baking" is tuned to improove render times with light baking.
I need to upgrade to 2.0 for that integration , right?
julius
Re: Redshift 2.0
Post by julius » 26 Jul 2016, 20:57
don't remember that.
there is a thread with RS 2.0 new features on the RS forum. Take a look at this or in your property menu : you should see a "redshift rendermap" option.
mc_axe
Re: Redshift 2.0
Post by mc_axe » 26 Jul 2016, 21:09
julius wrote:don't remember that.
Yep its not there i still have the first version i got 1.3.26
That alone is good reason to upgrade :P
thx anyhow!
mc_axe
Re: Redshift 2.0
Post by mc_axe » 05 Oct 2016, 01:42
some xsi specific fixes on versions > 2.0
[XSI] Added Redshift_ApplyMaterialID command
[XSI] Fixed bug that would ignore the texture filtering property overrides on normal, environment and camera map map shaders
[XSI] Added initial support for RenderMap baking
[XSI] Fixed bug that would prevent blending of RS Skin materials (bug introduced in 2.0.11)
[XSI] Fixed bug that would produce crashes during baking with multiple GPUs
[XSI] Modified (and hopefully fixed) code that was producing a crash during baking. More info here: https://www.redshift3d.com/forums/viewthread/6134/
[XSI] Fixed bug that prevented certain Matte options from being correctly set on strands and hair
[XSI] Fixed bug that resulted in a script error when attempting to assign a new Redshift material to a partition on a non-active pass using the Render > Get > Material menu
[XSI] Fixed bug that caused incorrect channel naming when more than 1 Depth AOV was present
[XSI] Fixed compiler related bug that could cause point-cloud GI to not be generated for native Softimage material nodes
[XSI] Fixed error message “The parameter ‘ss_amount=’ does not exist on the Redshift Skin…”
mc_axe
Re: Redshift 2.0
Post by mc_axe » 22 Apr 2017, 21:36
Update on xsi specific changes in versions > 2.0.39
v2.0.41
[XSI] Added OpenVDB support
[XSI] Fixed bug that prevented Redshift menu from working correctly on older versions of Softimage
v2.0.56
[XSI] Fixed bug that caused proxies to display incorrectly in the viewport after scene is saved and reloaded
v2.0.63
[XSI] Fixed bug that caused the cone expression of Redshift spot lights to break when exporting/importing emdl
v2.0.71
[XSI] Added support for motion blur on volume grids
[XSI] Fixed bug that caused an empty port in the volume pass shader list to disable the volume shaders completely
v2.0.88
[XSI] Fixed bug in the Integer Attribute shader that prevented it from working properly
v2.0.91
[XSI] Fixed bug that caused matte parameters to not update correctly when switching the active pass
Here is the log with all the upgrates so far (for all aplications + general fixes and additions) (Customer Builds after v 2.0.1)
Re: Redshift 2.0
Post by Bullit » 23 Apr 2017, 15:31
So Softimage is not in v2.5?
mc_axe
Re: Redshift 2.0
Post by mc_axe » 23 Apr 2017, 17:31
Bullit wrote:So Softimage is not in v2.5?
2.5+ are all just Experimental Builds.
Softimage is supported amongst others, and there are also a few xsi specific changes happening in those 2.5+ builds, i posted only the log for Customer builds = tested and stable versions.
Experimental builds are a little bit ahead in time with fresh features and fixes.
New implementations like Houdini are getting the most attention atm that is true.
But General additions / optimizations /fixes with [all] prefix apply for all applications.
So no wories Softimage still receiving alot of upgrates.
If anyone wonders C4D is in alpha since Sept.
I just installed the latest version i can use, my licence allows versions up to 2017 02, so now i can only watch new features comming but cannot touch them :P
julius
Re: Redshift 2.0
Post by julius » 24 Apr 2017, 07:07
of course yes, Redshift 2.5 will cover Softimage.
The experimental builds are already working.
EDIT : too late ! ;)
Re: Redshift 2.0
Post by Bullit » 27 Apr 2017, 10:58
Thank you both.
