Redshift - pre-purchase questions
Post by Hirazi Blue » 03 Jun 2016, 09:10
Having decided not to jump on the very tempting Houdini Indie bandwagon, mostly because I dread the necessary “learning curve” involved, I came to the conclusion I should invest my money in a Redshift license. But before I do I still have some questions. The current demo version of the software is 1.3.35 (or 1.3.37?) and the two limitations I have found are that there are no toon shaders and Redshift doesn't seem to support volume shaders. I understand I do not have to start holding my breath for toon shaders in Redshift, but volume shaders would be most welcome. Are these part of version 2 of the renderer? And how far along is the development of version 2? Will a stable version be released any time soon?
And finally: what else is “missing” from Redshift that I might have overlooked?
x_x
Re: Redshift - pre-purchase questions
Post by NNois » 03 Jun 2016, 10:15
My 2 cents...
A toon shader can be done with a simple gradient plugged in an incidence shader ;-)
Or better, done by using a full reflection image map (you know the mirror balls) like the matcap_058 here https://www.si-community.com/forum/v ... 9&start=10 the wonder of this is that's displaying in your softimage HiQuality viewport ;-)
There's absolutly no reason to not jump in
Post by Hirazi Blue » 03 Jun 2016, 10:18
How about ICE volume shading?
mattmos
Post by mattmos » 03 Jun 2016, 10:44
I still use the mental ray toon shader - yes you can fake some stuff in RS but its much easier to revert back to MR just for the jobs that require toon stuff.
They're making a lot of progress with volumes in RS but it will still take a while to get to the level of flexibility/functionality that MR had (albeit with custom shaders from Holger). I think we'll see more once people are able to write custom shaders/have access to an API.
Lastly I do miss the range of procedural shaders that were available for MR. Not as much as I thought, but for noise in AO etc it would come in handy to have more options for RS.
Post by NNois » 03 Jun 2016, 13:24
Redshift Volume rendering is supported on Houdini why it's not in Softimage ??
Post by NNois » 03 Jun 2016, 13:27
NNois wrote:Redshift Volume rendering is supported on Houdini why it's not in Softimage ??
ok Volume is a 2.0 feature that's why
