Slide Relax Brush
m|SlideRelaxBrushAuthor: Martin Yara
A one-click solution for setting up XSI for smooth/relax weightmap painting. Start painting by selecting either the menu item Modify > Deform > m.Slide Relax Brush or the item with the same name inside an object's context menu.
From the si-community thread: This is a simple tool that uses a combination of Shrink Wrap, Relax, Gator and Weight Maps to relax a mesh without changing its shape, or at least, not by much. Something similar to slide edges. It also has an option to preserve UVs using Gator. It is very simple, but very useful for my modeling, I wish I had done this a long time ago.
Video demo on Youtube.
local backup: mSlideRelaxBrush.py (copy to any Plugins folder)
myara
Slide Relax Brush
Post by myara » 28 Apr 2016, 10:03
This is a simple tool that uses a combination of Shrink Wrap, Relax, Gator and Weight Maps to relax a mesh without changing it's shape, or at least, not by much. Something similar to slide edges.
DOWNLOAD
http://skymill.co.jp/tools/Softimage/mS ... xBrush.zip
INSTALL
It's a plugin file, so copy it into your Plugin folder.
HOW TO USE
You'll find a m.Slide Relax Brush button in your Deformers menu and your Object Right click context menu.
M.Yara
julius
Re: Slide Relax Brush
Post by julius » 28 Apr 2016, 13:05
thanks a lot !
:-bd
mc_axe
Post by mc_axe » 28 Apr 2016, 17:53
Sweet! one guy told me how to do this manually, but i forgot :)
myara
Post by myara » 28 Apr 2016, 18:47
it is pretty easy, it takes a lot of steps but it isn't difficult. I made a smooth / relax brush years ago, but I've never though about combining it with shrink wrap which turned up to be great because using only smooth deforms the shape.
To do it manually:
duplicate your obj
hide dup
apply shrink wrap to your obj and take the dup as reference
apply relax
Move both operators above the modeling stack
be sure that relax is below shrink op to have the slide effect.
create a weight map
connect the weight map with relax
and to get preserve UV:
apply gator and take the dup as reference
rename old UVs
transfer UVs
rename UVs to match the original UVs name so they will be displayed in the viewport
use your brush and paint.
freeze operators
delete weight maps
delete dup
or you can do it with a few clicks now ;)
M.Yara
CYTE
Post by CYTE » 10 Oct 2016, 18:54
Hey myara,
your tool is brilliant! could you insert a button that disables the reproject in the smooth and disables the shrinkwrap operator?
this way the tool could also be used for a normal smooth. this would be very handy.
thanks alot!
CYTE
Post by rray » 10 Oct 2016, 19:48
For smooth you can also use the normal build in method: create a weigthmap, smooth, connect the smooth strength paramter to the weightmap, then paint on the map.
CYTE
Post by CYTE » 11 Oct 2016, 07:09
Hey rray,
Thanks for your reply.
Your described workflow is absolutly doable. the nice thing about myaras method is the one click solution. And if it would also work for normal smooth i think the tool would be even better.
By the way thanks for your fantastic website :-bd :x
CYTE
myara
Post by myara » 12 Oct 2016, 11:34
Added a 'Shrink Wrap' option that changes the Shrink Wrap Amplitude from 0 to 10 by default (-100 to 100 manually).
Hope it helps.
M.Yara
Post by rray » 12 Oct 2016, 11:44
Hey CYTE you're welcome, and now there's a great solution for that :D - thanks myara.
myara
Post by myara » 12 Oct 2016, 11:52
NP. There was a little bug with objects using Scene Material. Fixed it and uploaded again.
M.Yara
CYTE
Post by CYTE » 12 Oct 2016, 18:31
Hey myara,
thanks for your effort! I dont want to be annoying sry :D
but the reproject in the smooth operator is still active, after i turn down the shrink wrap value to zero.
so its still not just a "normal" smooth after setting shrinkwrap value to zero.
thanks again for your great work and sry for me being annoying.
cheers
CYTE
myara
Post by myara » 13 Oct 2016, 04:20
CYTE wrote: but the reproject in the smooth operator is still active, after i turn down the shrink wrap value to zero.
I don't mind adding a few things here and there when I have some free time, but I don't understand what do you want.
When Shrink Wrap Operator's Amplitude is in 0, it's the same as muting it, or even, delete it.
The Preserve UV option is using Gator to reproject the UV, but it's an optional checkbox that is disabled by default.
M.Yara
CYTE
Post by CYTE » 13 Oct 2016, 13:22
Hey Myara,
sry for the confusion. i guess the problem is that i used the wording "normal smooth" were "standard smooth" would have been more appropriated.
I made a picture to illustrate what i mean. in the end its quite simple.
I thank you for your time and patience!
cheers
CYTE
myara
Post by myara » 14 Oct 2016, 13:36
Ok, Added a Reproject option.
The GUI is bigger and uglier now but it works better I think.
I think Shrink Wrap isn't necessary in most cases so I disabled it by default.
M.Yara
CYTE
Post by CYTE » 14 Oct 2016, 14:55
Hey Myara,
thank you very much!
super handy tool! :x
there is just a slight issue with freeze. it ignores the weightmap for me and smoothes out everything.
CYTE
myara
Post by myara » 14 Oct 2016, 16:42
I changed a few lines that may have broken that part. Damn.
I'll be out until Wednesday, I'll fix it then.
M.Yara
