ICE tip #5989 - hide stuff in compounds dynamically
Post by rray » 15 Feb 2016, 21:32
There's a PPG logic section in the compound properties for ICE compounds, just as there is for render tree compounds.
But it's quite limited compared to render tree compounds.
What works well hovever is dynamically Showing/Hiding parameters.
For example use this script to hide a profile curve you don't need so it won't take away valuable space in your compound's PPG.
def Active_OnChanged():
		PPG.ProfileCurve.Show(PPG.Active.Value)
==OFF==
==ON==
anhungxadieu
Skype: nguyenvuducthuy
Re: ICE tip #5989 - hide stuff in compounds dynamically
Post by anhungxadieu » 16 Feb 2016, 01:49
cool, thank!
Until now i really don't know how to hide fcurve when it's always show up :ymblushing:
Pooby
Post by Pooby » 16 Feb 2016, 09:24
Looks very useful, thanks. I have a few compounds where those Fcurves overpower everything
danyargici
Post by danyargici » 16 Feb 2016, 09:31
Indeed, overpowering is the perfect description. Would have been good to know about over the years!
Post by rray » 16 Feb 2016, 09:56
Glad it's of use! One thing to mention is there should probably be another copy of the line
in the on init callback as well. Not sure whether it's necessary.
