Redshift now has RenderMap baking
Manticor
Post by Manticor » 11 Feb 2016, 07:42
Redshift has added rendermap baking to their xsi plugin
[XSI] Added initial support for RenderMap baking
Check the redshift forums for more info
I'm interested to see how this compares with xnormal in terms of speed
Re: Redshift now has RenderMap baking
Post by Bullit » 11 Feb 2016, 20:25
Good news. Any ETA for volume stuff?
mc_axe
Post by mc_axe » 12 Feb 2016, 00:08
Gr8 news hopefully an ultimapper killer
*not that Ultimapper is alive these days, but you know,, it unlocks potentials
For example : Use only SI and Substance and produce a pbr real time asset, based on a subdivision HR model for example
gaboraa
Post by gaboraa » 12 Feb 2016, 17:53
mc_axe wrote:Gr8 news hopefully an ultimapper killer
Substance's integrated baker is one of the fastest out there IMHO, I am not depending on Ultimapper anymore.
mc_axe
Post by mc_axe » 12 Feb 2016, 22:36
I have a question: Did you manage to get gr8 quality AO with substance bake? I was kinda disapointed, in comparisson with the quality of the incredibly slow ultimapper.
Maybe i followed the wrong tutorial :(low res + NM ---bake-->AO).
gaboraa
Post by gaboraa » 13 Feb 2016, 09:25
Actually Substance does not give you quality AO result as Xnormal or Ultimapper does because Substance requires AO for masking the mesh only. If quality AO is required, I recommend Xnormal which is extremely reliable and fast. But as a workaround, I usually blur the Substance AO which gives almost the same effect as Xnormal gives me.
mattmos
Post by mattmos » 13 Feb 2016, 11:22
Bullit wrote:Good news. Any ETA for volume stuff?
No dates yet but it seems to be weeks rather than months away.
mc_axe
Post by mc_axe » 13 Feb 2016, 17:53
New experimental version today:
* [XSI] Fixed bug that would prevent blending of RS Skin materials (bug introduced in 2.0.11)
* [XSI] Fixed bug that would produce crashes during baking with multiple GPUs
And this reply is from y/day (volumetrics):
It’s getting there. We spent the better part of the last 3-4 weeks working on sampling optimizations. They are crucial for good performance. Pretty soon (next week) we’ll be adding GI and some shading capabilities.
As with all rendering features in Redshift, this will be a continuously improved one. But we think (hope!) people will like what they see even in the initial release! wink
Thanks for your patience.
Post by Bullit » 13 Feb 2016, 23:52
Many thanks for feedback mc_axe
Post by FXDude » 14 Mar 2016, 23:20
And very soon a "store_color_in_channel" equivalent (which is *awesome* :-! )
Panos Zompolas wrote:Hey guys,
This feature (“Custom AOVs”) will be arriving in one of the RS 2.0 releases.
-Panos
Post by FXDude » 16 Jun 2016, 20:20
Great News!!
(SI) Redshift now has volume VDBs ;;)
https://www.redshift3d.com/forums/viewthread/7252/P15
_________________
Nicolas Burtnyk
Version 2.0.42 is now available.
Download installer
Download zero-install zip package
Download Linux installer
Release Notes
* [XSI] Added OpenVDB support
* [All] Adding preliminary support for Pascal-based GPUs (GTX1070/GTX1080)
* [All] Added workaround for random crashes caused by CUDA 8.0 compiler bug on Maxwell (5.x) compute GPUs
_________________
vlanger
HAPPY HAPPY JOY JOY
_________________
Anatoly B
YEAH BABY !!!
_________________
ionart
XSI VDB is supporting sequences?
_________________
Adrian
yes
_________________
kazuyuki kamada
Great! Softimage OpenVDB How to use?
_________________
Adrian
Get > Primitive > Redshift Volume Grid, connect a rsVolumeMaterial to the shader and set the density and emission channels to the appropriate name from the VDB. The names of the existing VDB channels are printed in the log.html file so if you don’t know what you have inside the VDB check the log.
It would be nice to have an option to print the VBD channels in the script editor along with the rest of the info.
One more thing: lights need volume contribution > 0 in order to affect the volume.
A
_________________
ionart
Thanks Adrian,
is there “any” syntax for the sequence?
file names:
smoke00000.vdb - smoke00100.vdb
thanks
Charlie
_________________
Adrian
Fly I don’t know. It does not work on my side even if the controls are there. In Maya for instance you have a <f> token instead of the digits but in XSI it does not work.
Will figure it out and let you know.
A
_________________
vlanger
I have no softimage around at the moment but try: ####
or [frame]
_________________
ionart
efx_cache\SCN004_VDB\smoke#####.vdb
with this syntay.. its looking for the sequence better… sometimes i get this message:
’ WARNING : [Redshift] Failed to find volume file efx_cache\SCN004_VDB\smoke00022.vdb. Volume will be empty
_________________
Adrian
#### works.
[frame] works if the digits in your vds correspond to the frame value which is just a number with no leading zeroes
Thank you
A
_________________
ionart
okay… in cases i have to build a new container…
framenumbers are replaced with: #####
working fine!
cheers
mattmos
Testing out openvdb in SI smile
________________
fsgfx
looking great…
how long did one frame take..?
________________
mattmos
first few frames were around 5 seconds, last few were around 35 secs, at 1080p, with 1 titan X, and 2 titans.
Just physical sun/sky, 16/64 main samples and brute force primary and secondary at 1024.
:x
Post by FXDude » 16 Jun 2016, 22:15
(other) not bad news!
Possible to Implement Weta’s Hair Model?
https://www.redshift3d.com/forums/viewthread/7245
___________________
Michael Rochefort
Found this a while ago while looking into Renderman. I was wondering if there is a way to implement this, similar to how it was done in PRMan.
Melanin2Color v1.1 for Softimage:
gumSax
(Big thanks to Adrian Cruceru)
//CHANGELIST
. Changed naming to match Adrian’s script
. Added melanin mix support.
//INSTALL: Just extract the archive to the \Data\RTCompounds folder in your workgroup or user folder.
//USAGE:
Add the melanin2color node to your rendertree and connect the 3 color outs to the similarly named slots in the Redshift Hair Shader.
Melanin == 0 results in white hair, 1 in black, 0,2 in blond hair color
Melanin Mix == 1 uses pheomelanin pigments, 0 uses eumelanin pigments
Dye Color == controls overall color of hair (multiplied)
Melanin2Color_v1.1.zip
Post by Hirazi Blue » 17 Jun 2016, 07:15
Do you have a link for Melanin2Color? :-\
edit: found it on the "closed" Redshift forum...
