I have a (probably very simple) problem, but I'm not using ICE as often as I should, so I can't make it work.
The problem is that I can't find a way to exclude certain parts of a mesh from an ICE tree.
The mesh is pretty heavy, and I'd like to have the effect localized (it's a tension map, pretty much the same setup as the one by Paul smith). Any idea how to approach this issue, and exclude a point cluster from the calculations? Any help is appreciated
