Eric made some tutorials for use his tools with Fabric
--- emReader (Fabric) Tutorial 04 ---
The following things are demonstrated and/or explained in this tutorial:
starting at 00:00 > "Introduction".
starting at 01:45 > "High/Low Level Presets".
starting at 02:20 > "Setup from Scratch (Polygon Mesh)".
starting at 04:20 > "Setup from Scratch (Particles)".
starting at 07:12 > "Difference between 'normal' and 'adv' Preset".
starting at 09:30 > "Quick look at a few Samples".
starting at 13:07 > "Using emReader in Fabric for Maya".
starting at 13:59 > "Using emReader in Fabric for Softimage".
starting at 15:08 > "Intermezzo".
starting at 15:27 > "How to use emReader in KL Code".
starting at 20:19 > "Outro".
Fabric Engine Tutorial 01 - Installing Mootzoid Extensions
--- Fabric Engine Tutorial 01 ---
starting at 00:22 > "Where to download Mootzoid Extensions and Samples".
starting at 00:36 > "Where to download Fabric Engine".
starting at 01:18 > "Extract Fabric Engine".
starting at 01:37 > "Extract Mootzoid Extension and Samples".
starting at 02:52 > "The Content of the Mootzoid_Fabric Folder".
starting at 04:01 > "Launch Fabric Canvas".
starting at 05:02 > "Set the Environment Variables".
starting at 06:23 > "Launch Fabric Canvas again and check if things are working".
starting at 07:15 > "Outro".
emPolygonizer5 (Fabric) 5.20 Tutorial 03 - Walk Through
--- emPolygonizer5 Tutorial 03 (Fabric) ---
starting at 00:18 > "What does emPolygonizer do?".
starting at 01:14 > "Where are the presets?".
starting at 02:29 > "Building a Setup from scratch (1)".
starting at 03:50 > "Building a Setup from scratch (2)".
starting at 04:37 > "Building a Setup from scratch (3)".
starting at 06:46 > "Caching the Meshes to Disk".
starting at 09:22 > "Quick look at a few samples".
starting at 11:43 > "Building a simple Tool in Maya".
starting at 14:51 > "Where's the Documentation?".
starting at 17:00 > "Outro".
Motozoid tools with Fabric Engine
Re: Motozoid tools with Fabric Engine
I ran into these last night, what a great way to show off FE
Yes, Mr.Motz is an excellent teacher.
