Hi
Some time ago I was trying to make a plugin to align uv edge horizontally or vertically. I was unsuccessful.
So I asked Svyatoslav Shumikhin to try, and as a reply I got almost working plugin. And after another day it was working as intended.
Also Svyatoslav did not mind, that I shared it with everyone. So here is the link:
https://github.com/sshumihin/Softimage_ ... lignUVTool
And video how to use it:
Please check other plugins by Svyatoslav http://numbervalley.weebly.com/
Align UV Tool
Grubber
Align UV Tool
AceMastermind
Re: Align UV Tool
Very nice and thank you for sharing! This plugin also works with Mod Tool 7.5!
mc_axe
Re: Align UV Tool
Yes please someone make UV editor plugins
I have lots of ideas for improvements,
AceMastermind
Re: Align UV Tool
I know ringpull, myara and Jester have made plugins for the UV editor and you can find several on rray.de/xsi in the form of plugins and compounds:
**partly works with Mod Tool 7.5
UDIM Tools has a script error on line 190:
should be:
@Grubber
Your video is dead
- mMirrorUV
UV netalign
UV Edit by Mesh*
Deform by UV
UV Stamp*
Scale UVs 2.0
Jester's Toolkit**
Convert between Mesh and UV
UDIM Tools*
var v = get_viEew();Code: Select all
var v = get_view();@Grubber
Your video is dead
mc_axe
Re: Align UV Tool
thnx m8 for sharing this list i knew only one or smthin!
I had in mind an idea, if any one can implement , ill make a statue to that person.
Selection Plugin. integrate all the cool component selection functions that doesn't work for a rly weird reason, within UV editor.
For example:
-all loop selection functions
-range selection functions
-Grow loops shrink loops
-Select outline of selected polygons
-select clusters,
-grow selection/shrink
*etc
The chalenge in this plugin is apply this selections with respect to islands.
Please some1
do it or teach me
I lost countless hours
For example:
-select clusters,
*etc
Please some1
