ICE tip #5988 - uv to location
UV2Location for meshesAuthor: Reinhard Claus
This scene demonstrates how to use the 'reinterpret location' node to look up locations and mesh attributes from positions in the uv space of an object. The scene creates a 'UV clone' of a mesh, looks up closest locations on it and transfers attributes (in this case point position) from the original object.
Used like this, it can "texture" an object with a mesh or a curve, similar to Anto's 'Deform by UV'. Keywords: UV to Location, UV
local backup:UVToLocation_for_polymeshes_2.zip
Post by rray » 21 Dec 2015, 16:25
Now that the "reinterpret geometry" bug is fixed, this method works nicely for looking up locations from UV on poly objects:
* have an object with uvs ready (get->lizard)
* create a copy, use ICE to move each point to its uv coordinate (for example using uvmorph compound)
* lookup closest location on uv morphed copy, reinterpret back to original
(the attached scene additionally "explodes" the uvs into uv islands)
Re: ICE tip- uv to location
Post by rray » 21 Dec 2015, 16:27
I'm wondering whether this can be done with 1 mesh only, with 2 ice trees
Post by rray » 21 Dec 2015, 18:19
Of course that's possible ;)
Not only "Set Data" can be used on other objects than "self" - also "Add Point" !
This way the evaluation order of the two stacks can be nicely controlled.
all in 1 ICE Tree on the Lizard mesh:
* save topology, disconnect uv islands
* morph to uv
* add points on pointcloud at morphed locations using closest locations
* morph back to original positions
* move pointcloud's points to emit locations
* restore topology
reinterpret not even needed :ymblushing:
anhungxadieu
Skype: nguyenvuducthuy
Post by anhungxadieu » 22 Dec 2015, 02:01
rray wrote:Of course that's possible ;)
* morph to uv
* restore topology
hi,
Can you share this scene? thank you!
Post by rray » 22 Dec 2015, 02:49
Thanks for your interest anhungxadieu, will do that tomorrow
Post by rray » 22 Dec 2015, 14:02
If you don't need the old topology back, you can skip the extra closest lookup in the end
anhungxadieu
Post by anhungxadieu » 23 Dec 2015, 01:49
hi rray,
thank you! :ymhug:
gaboraa
Post by gaboraa » 23 Dec 2015, 10:36
Thank you, it is great to learn how to do that!
Post by rray » 23 Dec 2015, 13:43
you're welcome - btw the ICE tree on the lizard can be frozen if the uv's don't need to be changed later
