Hi, I was planing to come back a little to modeling, and do think this tool by Hans Godard would be so helpful in a lot of situations (see 5:09 mark in this video)
Does anybody have an tip on how to go get started writing something like this, ideally in ICE?
It's like a smooth (vertex average) but it fits much better into the unselected verts.
no idea how to approach that technically.
-rr
Laplacian fixer ICE
Laplacian fixer ICE
Tekano
Re: Laplacian fixer ICE
Hi rray here is the algorithm, looks pretty easy to do in ICE, not sure about the plugin if you get stuck can knock up a quick tree, it looks like its just move each point to nearest 4 neighbors or very similar
https://en.wikipedia.org/wiki/Laplacian_smoothing
From video, looks like proportional tweak tool performed after tweak, bounded by two selections. With only one direction of shrink or grow, according to 'details are coming from' option. I think there is no average of point positions, directly. More like average/smooth of some scalar attribute, used to modulate the smooth step (or something like) interpolation of delta against original. While 'repeat smooth' method is just stopped once the bound (defined by second selection) is reached. So in ICE world, something similar to ''deformation with bulge'', or "dent and bulge" factory sample - but, with plain 'repeat smooth' instead of 3d distance based one. It seems he used similar method in other parts of video, too.
Tekano thanks for the link. This is probably used somewhere as a part of it but I think there must me something more going on than just point smoothing, some additional step, because the transition into the unselected points is so nice and continuous. I tried but never could get this effect using just smoothing.
Mathaeus you mentioned deltas which made me think about that it might work similar to delta mush. Going to read up on how that works again, maybe it's the deltas that are smoothed with the Laplacian method.
-rr
-rr
I'm wondering whether it works with only two selections, or maybe any number. If he uses something like shrink selection, maybe there's some way of "bleeding" the unselected transforms into the selected parts.
At least, my explanation is based on two selections, where one is start, second is end of effect. According to last example, with mouth, where effect does not extend into complete selection - I think there's a kind of grow from first selection to the just a first bound of second, where steps were used to modulate the final offset.rray wrote:I'm wondering whether it works with only two selections, or maybe any number.
According to first example with cylindrical thing, where it takes the modified orientation into account, too - I'd believe this is blend of two complete transforms, created by movement of manipulator (smooth step, bezier, whatever), modulated by mentioned grow-shrink. "Grow-shrink" is "smoothed", here.
That clip shows awesome work by the way.
Yet all require python and or C++ to acheive. Whereas in soft...
