Greetings
My name is Fran. I'm learning Computer Graphics art since 3 years. I Live and work in Barcelona, Spain (currently). I've registered on this website to learn from you and help whenever I can, I hope to learn so much and be as helpful as possible.
I start with my first question.
Actually I'm working in a render with some passes. One object has a fast skin Shader.
]My problem is that I don't know how can I create a shadow pass with this shader on an object. I tried changing the material partition and adding ( desactivating ) some override parameters, but nothing. In depht pass I had the same problem
The fast skin shader appears in this pass.
What Can I do?
Fast skin shader and shadow pass
Soth3dlife
Re: Fast skin shader and shadow pass
The Fast Skin simply doesn't seem to do passes AFAIK
You could try ez-sss-fast-skin. I couldn't get this to work anymore, but in this post shushens claims he got it working...
Soth3dlife
Thanks. It seems a great way. I've tried before another way.Based on Ben Neal's Videotutorial ( from Gnomon ) and it works!
