Is there any magic to it? When I import an alembic file with the ending _0001 and scrub through the timeline noting changes. Also the edges of the fractured object (voronoi from Houdini) show up. I assigned point normals in Houdini.
But as I said, it seems to be only the _0001 files which shows up.
Anybody with any instructions how to do that? I just click on the alembic 1.1 importer, check the normals checkbox and import my object.
Tom
Importing an alembic sequence with Crate
El Burritoh
Re: Importing an alembic sequence with Crate
In the import options dialog, you also need to enable 'Multi-file'.
