Automatic Shutdown after Finishing Distributed Rendering
alias3ds
Post by alias3ds » 20 Sep 2015, 01:14
Hi all
I wonder is there any way to realize an automatic Shutdown after Finishing Distributed Rendering. Thanks.
Alias
Re: Automatic Shutdown after Finishing Distributed Rendering
Post by rray » 20 Sep 2015, 01:27
Hi, maybe you can look at some OS option, like in windows could probably use the task planner to shut down the machine after a longer period of the CPU being idle.
Post by NNois » 20 Sep 2015, 22:38
well,
Until i'm asking you first what app are you using to distribute your renders !!
If it's your's i'm sure you'll already know the right shutdown command, and if it's RR / Deadline / CGRU they all have that build in ;-).
If it's a simple .bat file with skip frames, just put shutdown.exe /s /t 00 (or his varient) on the next line. Some long time ago i use to made .bat file like that:
REM XSI Rendering 2 scenes sequentially
REM scene1
xsibatch -render \\server\project\scn\scene1.scn -skip on -pass "pass1,pass2"
REM scene2
xsibatch -render \\server\project\scn\scene2.scn -skip on -pass "pass1,pass2"
REM Rendering done ! shutting down in 30s !
shutdown.exe /s /t 30
you launch the bat on each machine and done ;-)
alias3ds
Post by alias3ds » 24 Sep 2015, 01:21
NNois wrote:well,
REM scene1
REM scene2
Hi NNois, Thanks very much for you help. I've tried the code you showed me, it works! Thank you :)
