Data Display for the Bend: http://prntscr.com/8b1q51
Data Display for an ouput port: http://prntscr.com/8b1qed
So the second one looks wrong to me as I want to output the bend rotation to used it on polygon islands or instances like I did in LightWave: https://www.youtube.com/v/Fd-ZeiNAmUY?start=172&end=178
Also, to my suprise when I tested the old WIP compound and output the data to actually bend some polygon islands... It worked just fine (gif below)... Is it because it's all being used to the same execution port (Set Point Position) ?
I'm a bit confused. Maybe in the end on a practical application this ends up not being a problem like it happened on my test, but I'm wondering why is this...
