Syntheyes 1508 with Geometric Hierarchy Tracking
Post by Bullit » 22 Aug 2015, 22:25
-Geometric Hierarchy (GeoH) Tracking. Spectacularly powerful and flexible new toolset for 3D tracking multi-level constrained hierarchies of moving parts, directly tracking supplied meshes or using normal (supervised) trackers. For example, use for kinematic chains such as articulated arms, car doors, or pizza boxes; or secondary tracking such as jaws, eyebrows, and bellies. Tracks and animates separate meshes or deforming meshes or mixtures. Integrates with conventional object tracks for secondary animation and motion capture shots for conversion to joint angles.
-New Hierarchy view and panel with drag reparenting. New layouts with hierarchy views.
-New Alembic export, BVH import and export, and updated exporters to support deforming meshes.
-Tracker cleanup can be run automatically after an AUTO-solve.
-New mesh pinning, edit pivots, lightsaber mesh deletion modes.
-More adaptability in room/panel/viewport switching. Click the *icon* to change just the panel. Click the *word* to change the room (panel and view). Hold shift key to change viewport but not the room definition. Preferences to control these behaviors.
-Multiple custom layouts... a new one is created whenever a non-custom layout is customized. Subsequent changes affect that custom layout (so they don't proliferate excessively).
-Around 100 more! Existing users should be sure to read the full list.
https://www.ssontech.com/nufeat.html
