Link for download: https://dl.dropboxusercontent.com/u/114 ... %200.7.zip
Link to post with last release data: https://www.si-community.com/forum/v ... 105#p52105
Some description: this is retopology tool for Softimage, It based on FabricEngine, so it should be installed too. May be the tool will work with old versions, but current 1.15.x is recommended. The core of FESRetopo consists from splice-operator and some extensions. So, it can be used also in Maya. For Softimage I additionally create some python script for automatically execution. So, after installation you will obtain item "FESRetopo" in Create - Poly. Mesh section
There are three parameters:
Reference - path to hi-poly file
Hide reference - when it checked, then the hi-poly reference is not drawing in the viewport
Hide HUD - when it checked, then edges and points are not drawing in viewoprt in the case of splice manipulator is disabled (for example, when rotate the camera).
In fact the global purpose of this tool is to build the analogue of Topogun for Softimage and take retopology process of some small models inside one 3d-progarm without import-export actions.
