Camera Correction
Camera Correction
Post by Bullit » 21 Jun 2015, 21:41
Any option to correct camera and make the vertical lines of objects vertical?
Re: Camera Correction
Post by Mathaeus » 21 Jun 2015, 22:32
If you mean something like Camera Correction modifier, I think the option in SI is to align camera and interest along Y axis, this makes vertical lines aligned. Then, enable projection plane in camera ppg, move 'optical shift', slghtly along Y, to get usual 'look at up' view. Not sure is it the exactly same result as Max modifier.
Post by Bullit » 21 Jun 2015, 22:57
Yes that is what i had in mind. Thanks, will try your idea.
