quickShutter
QuickShatterAuthor: Konstantin Kovalenko
aka QuickShutter. An easy to use shatter script working on any object, polygon or polygon islands selection. Includes unmerge.pys and unmergeParent.pys, two scripts which convert the polygon islands that were created to individual objects.
local backup: quickShatterAll.pys Unmerge.pys UnmergeParent.pys
sortSequenceAuthor: Konstantin Kovalenko
A file automation script that works in a given Windows folder. It detects any existing sequence of files and for each one, creates a folder with the same base name and then copies the files of the sequence into that folder.
local backup: sortSequence.pys
eistan
Skype: kovblood
quickShutter
Post by eistan » 18 Jun 2015, 18:25
Hi everyone, here is my new script quickShutter.
How it work, see video:
and bonus:
quickUnmerge - unmerging all merge objects and select them, and delete source object
quickUnmergeParent - unmerging all merge objects and select them, and move all object into source object (if you need to keep animation!)
sortSequence - this scripts work with your windows folder, where you have many image sequence and you need to move image sequence to folder with the same name respectively (but you need change 'e:\\test\\' to your path and Run)
download
https://drive.google.com/folderview?id= ... sp=sharing
Re: quickShutter
Post by wireframex » 18 Jun 2015, 20:16
Thanks a lot for sharing this :) :-bd
Phil
Skype: ondraise
Re: quickShutter
Post by Draise » 20 Jun 2015, 23:28
Wow nice! The shatter script you have is exactly what I was thinking to.. search for and use for a potential client. Beautiful. Thanks!
caledonian_tartan
Re: quickShutter
Post by caledonian_tartan » 22 Jun 2015, 07:24
this looks great!
unfortunately i get an empty mesh called "meshshutter01" when using quickShatterAll.pys.
using softimage 2015
SI 2015 @ WIN7-64
eistan
Skype: kovblood
Re: quickShutter
Post by eistan » 22 Jun 2015, 08:58
thanx guys
caledonian_tartan, sorry i dont have 2015 to test it, but i think it should work, im work in 2013
so, you select an object, and after you click Run in script editor, your object is gone??
can you screenshot whats the error and log write script editor
caledonian_tartan
Re: quickShutter
Post by caledonian_tartan » 22 Jun 2015, 09:51
i basically just put a cube in the scene and run the script.
at the end, just a empty polymesh is left. no errors.
#create a cube and subdivide a little bit
Application.CreatePrim("Cube", "MeshSurface", "", "")
Application.SetValue("cube.polymsh.geom.subdivu", 24, "")
Application.SetValue("cube.polymsh.geom.subdivv", 24, "")
Application.SetValue("cube.polymsh.geom.subdivbase", 24, "")
Application.FreezeObj("", "", "")
#running the script
Application.GetPrim("PointCloud", "", "", "")
Application.SetValue("pointcloud.Name", "pcshutter01", "")
Application.GetPrim("EmptyPolygonMesh", "", "", "")
Application.SetValue("polymsh.Name", "meshshutter01", "")
Application.ApplyOp("ICETree", "pcshutter01", "siNode", "siPersistentOperation", "", 0)
Application.AddICECompoundNode("Build Slice Planes", "pcshutter01.pointcloud.ICETree")
Application.ConnectICENodes("pcshutter01.pointcloud.ICETree.port1", "pcshutter01.pointcloud.ICETree.Build_Slice_Planes.execute")
Application.SetValue("pcshutter01.pointcloud.ICETree.Build_Slice_Planes.Reference1", "cube", "")
Application.ApplyOp("ICETree", "meshshutter01", "siNode", "siPersistentOperation", "", 0)
Application.AddICECompoundNode("Create Basic Shatter from Point Cloud", "meshshutter01.polymsh.ICETree")
Application.ConnectICENodes("meshshutter01.polymsh.ICETree.port1", "meshshutter01.polymsh.ICETree.Create_Basic_Shatter_from_Point_Cloud.Execute")
Application.AddICENode("GetDataNode", "meshshutter01.polymsh.ICETree")
Application.SetValue("meshshutter01.polymsh.ICETree.SceneReferenceNode.reference", "pcshutter01", "")
Application.ConnectICENodes("meshshutter01.polymsh.ICETree.Create_Basic_Shatter_from_Point_Cloud.Point_Cloud_Name", "meshshutter01.polymsh.ICETree.SceneReferenceNode.outname")
Application.SetValue("meshshutter01.polymsh.ICETree.SceneReferenceNode[1].reference", "cube", "")
Application.ConnectICENodes("meshshutter01.polymsh.ICETree.Create_Basic_Shatter_from_Point_Cloud.Polygon_Mesh_Name", "meshshutter01.polymsh.ICETree.SceneReferenceNode[1].outname")
Application.SetValue("pcshutter01.pointcloud.ICETree.Build_Slice_Planes.Seed", 679, "")
Application.FreezeModeling("meshshutter01", "", "siUnspecified")
Application.DeleteObj("cube")
Application.DeleteObj("pcshutter01")
SI 2015 @ WIN7-64
Re: quickShutter
Post by Daniel Brassard » 22 Jun 2015, 14:35
Hi Caledonian_tartan
In your code, the line defining "meshshutter01" should it not be?
Application.SetValue("EmptyPolygonMesh.Name", "meshshutter01", "")
caledonian_tartan
Re: quickShutter
Post by caledonian_tartan » 22 Jun 2015, 14:54
unfortunately not. polymsh is fine.
if i prevent object deletion and freeze and change this: (set integer value to one)
Application.SetValue("meshshutter01.polymsh.ICETree.Create_Basic_Shatter_from_Point_Cloud.Init_PolyMeshTopologyArray.IntegerNode.value", 1, "")
i can see one chunk...
but building an array there doesn't help
SI 2015 @ WIN7-64
Re: quickShutter
Post by Daniel Brassard » 22 Jun 2015, 15:10
What does your ICETree on the pointcloud and EmptyPolygonMesh look like? Comment the DeleteObj line in the script and check Softimage scene structure and both IceTree.
The script is basically an automation of this on whatever polygon mesh is selected at the time
http://download.autodesk.com/global/doc ... 1-1033.htm
