I have an fcurve from a camera track. It doesn' need to match the original camera so I'd like to reduce the high-frequency noise interactively. I know of "Curves > Curve Processing Options > Smooth" but I'm wondering ... can this be done non-destructively with an expression? My only frame of reference is from After Effects with the smooth(time width, samples) expression.
Thanks,
Marc
FCurve Smooth Expression
Re: FCurve Smooth Expression
There isn't a preset function for it like AE, and there may be a way to specify a range of frame integers,
but this Expr. works
(averages current Y value with 2 frames before and after)
You can have it reffer a null's anim or custom (float) parameters under your object (using the custom pset wizard)
av(
at_frame( Fc - 2, null.kine.local.posy ),
at_frame( Fc - 1, null.kine.local.posy ),
at_frame( Fc, null.kine.local.posy ),
at_frame( Fc + 1, null.kine.local.posy ),
at_frame( Fc + 2, null.kine.local.posy )
)You can have it reffer a null's anim or custom (float) parameters under your object (using the custom pset wizard)
chepmedia
Thank you for this suggestion - it looks like it's just what I need . .. and I can just add more frame range to expand the averaging. Will let you know how this turns out.
Marc
Marc
