creating a straight line parallel to x axis using curves
agrmrs
hi friends
i'm trying to create a straight line parallel to x axis ..... i used a CV curve to draw that ......but how can i draw it 100% parallel to the "X" axis .... i tested some snap methods but didn't work
thanx
Re: creating a straight line parallel to x axis using curves
The easiest way to fix the line you're working with is to select all points and go to your right-hand panel and enter one new number in the y-box in the translate part of the transform panel... ;)
agrmrs
ohh that's a handy trick mate .....thanx
.....i really didn't remember that method
agrmrs
ohh i found another way ...... u can press Ctrl and scale only in "Y" direction ....when it snaps to the line the line becomes straight
Diurno
i think the quickiest way to draw it perfect paraller to an axis is to drawing the line with the snap to the grid turned on.
