Animation Clip Cycle Dependency - ERROR - why?
Skype: ondraise
Post by Draise » 29 Apr 2015, 20:51
# WARNING : 3000 - Animation Mixer is currently evaluating - Cycles/Re-entrancy not supported
What does this mean and/or imply?
Re: Animation Clip Cycle Dependency - ERROR - why?
Post by FXDude » 03 May 2015, 17:44
Did you try this?
Avoiding Cycles
To help you prevent creating cycles, you can do any of the following:
• Check where constraints already exist in a 3D view or in the schematic view — see Viewing Constraints and Their Information.
• Select an object and choose Constrain > Select Constraining Objects to see the objects to which the selected object is constrained.
• Type the command CycleChecking in the script editor and click Run to check an entire scene. Select the command and press F1 to get more information on it.
OR maybe even better,
Disabling Cycle Checking
You can disable cycle checking if you want to avoid unwanted warning messages in some situations where you know desirable cycles exist. There are two options on the Scene Debugging tab in Data Management Preferences that you can set:
• Disable cycle checking when applying animation operators
• Disable cycle checking when editing ICE trees
Skype: ondraise
Post by Draise » 04 May 2015, 14:03
Wow great, where did you find this info?
I'll immediately take a look into this. Must be one of my modified GEAR rigs.
