Hi guys,
Is there some way to view the displacement results (in shade mode, for exemple) in viewport without using Render Region?
Thanks,
Displacement in viewport
Leandro Oliveira
Re: Displacement in viewport
AFAIK this is not possible (but I could be mistaken, obviously
From the User's Guide:
Displacement affects the geometry of the object during the rendering process.
If it's not too complex, you could use a push opp on a texture, and see it in the viewport.
Leandro Oliveira
Interesting solution, Rork. I´ll try it.
Thank you, guys.
Thank you, guys.
