Is there anywhere rigged camera to see directly the DOF zone in the viewport ?
Note : I use VRay 3.0 for SI
Phil
Camera with DOF
Camera with DOF
- Skype: ondraise
Re: Camera with DOF
The viewport does not have DOF preview, but you could use the Render Region. Not sure how Vray plugs into the Render Region though...
tarkovsky
Re: Camera with DOF
Its not possible to tie the focal point to the camera interest? Otherwise you could maybe set the focal point by an expression of distance between camera and interest.
t
t
caledonian_tartan
Re: Camera with DOF
try this compound on an empty polymesh.
you probably need to pick the camera.
it gives you a plane for the focal point and sends its info to the vray lens shader.
you can eighter use the interest, set a custom focal distance or use the one from the vray lens shader.
unfortunately i don't see how to visualize the Sharp Zone...
EDIT:
I just found out that there is DOF in the High Quality Viewport!
Let me try to link it whit my compound and the VRAY Camera.
Fancy!
EDIT:
Fancy!
SI 2015 @ WIN7-64
Re: Camera with DOF
Thanks for all your answer, maybe my explaination was not so clear
In fact I'm looking for something like this who works with V-Ray camera :
A focus point with the focus zone you can change directly in the viewport
Bests regards
Phil
EDIT : Hey Caledonian just saw your post maybe you are close to my need
Bests regards
Phil
Re: Camera with DOF
Any news to help me ?
