Need help navigating a folder structure
Pete
Post by Pete » 18 Mar 2015, 10:53
Hi there,
Hey I'm having a bit of trouble with this script that should be pretty straight forward but I'm not very good at navigating order structures outside of xsi through scripting.
I want to save a file in a directory that is outside of the project and I don't really want to use specific directly names (so I can reuse it on other projects).
I'm starting off from within Project_XSI and I want to save into Project_Unity
I can get the project folder with with var ScenePath = Application.ActiveProject2.Path+"" but does anyone have any suggestions on where I could go from there?
Sorry it's a little hard to explain, but if anyone has any suggestions it would be great!
Thanks,
Pete
csaez
Skype: csaezmargotta
Re: Need help navigating a folder structure
Post by csaez » 18 Mar 2015, 11:53
Hi Pete,
I don't have Softimage in front of me, but looks like an easy task for python.
The snippet below should print the path to the parent directory of the current project.
import os
from sipyutils import si
project_path = si().ActiveProject2.Path
parent_path = os.path.join(project_path, "..")
print os.path.normpath(parent_path)  # prints normalized path
Hope this helps,
Cheers!
Post by rray » 18 Mar 2015, 12:03
yes, ".." for parent directory can be a part of the path, it should work the same in any scripting language if you have a path like
do..
var path_pic_in_other_folder = ScenePath +"\\..\\Project_Unity\\hihih.jpg"
Pete
Post by Pete » 18 Mar 2015, 22:38
Ahhh cool! Thanks guys, that's perfect!
