How define current selection type?
Xsinode
Post by Xsinode » 14 Mar 2015, 10:00
Hi i need some help.
Now i'm use three simple scripts for quick toggling from object filter to vertex/edge/polygon filter.
This example of Object/vertex toggle script. For each hotkey i'm use single script
currFilter = selection.filter;
if ( currFilter.name == "object" )
 SetSelFilter ( "Vertex" );
else if ( currFilter.name == "Vertex" )
 SetSelFilter ( "object" );
else if ( currFilter.name == "Edge" )
else if ( currFilter.name == "Polygon" )
And i want make this toggle sense to selection type (polymesh, surfacemesh, curve).
For example: if i'm select polymesh (avalible point/edge/polygon filters for toggling), if curve (avalible point, isopoint, knot for toggling) and etc
But i dont uderstand how i can get current selection type?
Maybe something like this:
currType = selection.type;
if (currType == "polymesh")
 SetSelFilter ( "Edge" );
if (currType == "crvlist")
 SetSelFilter ( "Isopoint" );
else if ( currFilter.name == "isopoint" )
else if ( currFilter.name == "Knot" )
And second question about scripting. I have script for quick subdivision level toggling
Dim objSelected, intSubDLevel, intNewLevel
Subdivide
Sub Subdivide
	Set objSelected = SIFilter( null, "sceneobject", true, siQuickSearch )
	If typename(objSelected) = "Nothing" Then
		objSelected="Nothing"
		LogMessage "Clear selection "
		Exit Sub
	Else
		intSubDLevel = GetValue (objSelected & ".geomapprox.gapproxmosl")
		' LogMessage "SubD Level : " & intSubDLevel
		If intSubDLevel => 4 Then
			intNewLevel = 0
		Else
			intNewLevel = 4
		End If
	End If
	' sets the selected object's sub-d level
	SetValue objSelected & ".geomapprox.gapproxmosl", intNewLevel
End Sub
How i can fix multiple selection error (for example if i'm select 2 objects with different subdiv level script set value to 0)
Thanks for reading
csaez
Skype: csaezmargotta
Re: How define current selection type?
Post by csaez » 19 Mar 2015, 02:31
You can check the selection type, but it will fail if nothing is selected... What you need is toggle the selection filter instead (python).
from sipyutils import si
si = si()
filters = {
    "object": "Vertex",
    "Vertex": "Edge",
    "Edge": "Polygon",
    "Polygon": "Vertex",
si.SetSelFilter(filters.get(si.Selection.Filter.Name))
Cheers!
