Undo/redo history
Xsinode
Undo/redo history
Post by Xsinode » 02 Mar 2015, 01:05
How I can use any command without adding it to undo/redo history ?
Re: Undo/redo history
Post by Hirazi Blue » 02 Mar 2015, 10:25
I assume you want to disable the logging of the commands in a script?
If so look for "Disabling Command Logging Temporarily" on this page
Xsinode
Post by Xsinode » 02 Mar 2015, 14:57
No. I want to perform operation (using script) not adding to undo/redo history.
For example: First i'm create cube and then im use custom operator. When i'm using ctrl+z (for undo). Softimage undoing cube creation instead of custom operator.
Sorry for english.
Post by Mathaeus » 02 Mar 2015, 15:23
afaik, command has to be "registered" in order to undo the entire thing at once. Perhaps easiest way is to put your script into plugin, generated by XSI plugin wizard - it creates complete 'car hull' for your engine.
Post by luceric » 02 Mar 2015, 15:53
in the script, you have to set the undo level to 0, which will clear the undo history and turn off the recording of undo.
you cannot just suspend undo recording temporarily without clearing the existing undo stack, because what's already in the undo queue cannot correctly work anymore.
Xsinode
Post by Xsinode » 02 Mar 2015, 19:06
Thanks for answers
csaez
Skype: csaezmargotta
Post by csaez » 06 Mar 2015, 09:20
There's a way to encapsulate your script into one big undo step by using the BeginUndo/EndUndo commands.
Application.BeginUndo()
# YOUR CODE HERE
Application.EndUndo()
If you're using python it is possible to wrap this up as a convenient decorator or context manager, here is an old blog post about this (shameless plug).
Hope this helps,
Xsinode
Post by Xsinode » 14 Mar 2015, 06:52
Thanks for answers
