Welding points on mesh (not boundary)
Xsinode
Post by Xsinode » 12 Feb 2015, 17:37
I want weld point on one single mesh (share the same position).
I find one old script (WeldMesh v1.1) but script dont work.
Please help
'WeldMesh v1.1 / Andrй Adam
'Welds all points that share the same position on a polymesh object.
Set oSelection = Selection
If oSelection.Count = 1 Then
If oSelection(0).Type = "polymsh" Then
Do
Found = False
oVertices = oSelection(0).ActivePrimitive.Geometry.Points.PositionArray
i = 0
While (i < UBound(oVertices, 2)) And Not Found
Vertice1X = Round(oVertices(0, i), 3)
Vertice1Y = Round(oVertices(1, i), 3)
Vertice1Z = Round(oVertices(2, i), 3) j = i + 1 While (j < UBound(oVertices, 2)) And Not Found Vertice2X = Round(oVertices(0, j), 3)
Vertice2Y = Round(oVertices(1, j), 3)
Vertice2Z = Round(oVertices(2, j), 3)
If Vertice1X = Vertice2X And Vertice1Y = Vertice2Y And Vertice1Z
Vertice2Z Then
ApplyTopoOp "WeldPoints", oSelection(0) & ".pnt[" & i & ", " & j &
Found = True
End If
j = j + 1
Wend
i = i + 1
Wend
Loop While Found
Else
LogMessage "Wrong Selection", siError
End If
Else
End If
Re: Welding points on mesh (not boundary)
Post by Daniel Brassard » 12 Feb 2015, 18:11
You are missing the equality sign at the end of the if
It should be
If Vertice1X = Vertice2X And Vertice1Y = Vertice2Y And Vertice1Z = Vertice2Z Then
This is an old visual basic script tested on XSI 1.5
Surely their is something better today. Did you try to select your object and execute the command modify>polygon >weld point > weld point closer than with a very low threshold like .001
There is even an ICE topo script.
julius
Post by julius » 12 Feb 2015, 18:11
did you tried the "filter points" option instead of scripting this ?
Xsinode
Post by Xsinode » 12 Feb 2015, 18:22
to Daniel Brassard
Ok. But i have error in 11 line
to julius
Which filter you mean? And what's next? I have mesh with around 10 similar places. If I select all needed pints and use Weild Boundary Points/Edges it's don't work. Sorry for bad english
Post by Daniel Brassard » 12 Feb 2015, 18:30
Copy and check the code I posted above.
Dan
Xsinode
Post by Xsinode » 12 Feb 2015, 18:41
Ok. I dont know why, but when I use you code i have ERROR in - [line 18] but thanks for help anyway.
to julius
Thanks man i understand you. Just I dont know about Filter Points tool. I'm so stupid sorry... :(
Softimage great software but not intuitive in some places for me.
Post by Daniel Brassard » 12 Feb 2015, 18:58
OK.
Just in case you want to try it again
'WeldMesh v1.1 / André Adam
	Do
	Found = False
	i = 0
			j = i + 1
					ApplyTopoOp "WeldPoints", oSelection(0) & ".pnt[" & i & ", " & j & "]"
					Found = True
				End If
				j = j + 1
			Wend
			i = i + 1
			Wend
	Loop While Found
Else
End If
Else
End If
Xsinode
Post by Xsinode » 12 Feb 2015, 19:02
BIG Thanks Daniel it working! \:D/
Post by Daniel Brassard » 12 Feb 2015, 19:09
Cheers! :D
julius
Post by julius » 12 Feb 2015, 21:18
go to model menu-->modify-->poly mesh-->filter points
this filter weld all the points placed on top of each other.
Xsinode
Post by Xsinode » 12 Feb 2015, 22:11
julius
Big thanks to you, I'm already find this tool. (see my post above)
julius
Post by julius » 12 Feb 2015, 22:13
ok, sorry, didn't understand.
