I'm having a hell of a time getting PyQt to work. I'm following all instructions Steve Caron gives at his Github page for installing his PyQtForSoftimage.addon - installing Python, Pywin, PyQt, setting environment variable Path correctly. But when I then install the addon Soft immediately returns the following error:
# File "<Script Block 2>", line 2, in <module>
# import sip
# ImportError: No module named sip
# - [line 2 in C:\Users\Administrator\Autodesk\Softimage_2015\Addons\PyQtForSoftimage\Application\Plugins\pyqt_example.py]
# File "<Script Block 2>", line 1, in <module>
# from PyQt4.QtCore import Qt
# ImportError: No module named PyQt4.QtCore
# - [line 1 in C:\Users\Administrator\Autodesk\Softimage_2015\Addons\PyQtForSoftimage\Application\Plugins\qtevents.py]Code: Select all
# WARNING : PyQt not found, etRenamerPyQt will not be loaded.So, just to start, does anyone have PyQtForSoftimage addon working in Soft 2015? And if so, what version of Python/Pywin/PyQt?
