clone shader node
Clone ShaderAuthor: caledonian tartan
Duplicates a node and creates expressions on each parameter of the clone to have them driven by the original parameter. Installs into the context menu of render tree nodes.
local backup: CloneShaderNode.xsiaddon (repackaged/fix for local backup)
caledonian_tartan
clone shader node
Post by caledonian_tartan » 27 Jan 2015, 15:31
i'm about to create a function to clone a shadernode oder icenode inside the rendertree or Icetree.
is fairly simple to place a plugin in the rightclick menu context of a icenode/shadernode:
	in_reg.RegisterMenu(constants.siMenuICENodeContextID,"test_Menu",false,false)
or
	in_reg.RegisterMenu(constants.siMenuRTNodeContextID,"test_Menu",false,false)
Duplicate(clone) and linking all parameters is a bit harder...
As duplicate does't seem to work, i use copy/paste.
Application.Copy("Sources.Materials.DefaultLib.Scene_Material.Phong")
Application.Paste("Sources.Materials.DefaultLib.Scene_Material")
how do i get this context without using the explicit names?
how do i get all the node's parameters i just right clicked on to be linked to the new copy?
(using python)
SI 2015 @ WIN7-64
caledonian_tartan
Re: clone shader node
Post by caledonian_tartan » 28 Jan 2015, 16:27
currently i should just know how to define the selected node to get the Node.Name...
:ympray:
SI 2015 @ WIN7-64
Post by FXDude » 29 Jan 2015, 08:59
I'm pretty sure there's a way to get selected node(s),
A bit in a crunch right now but I'll look into it soon,
And that will be a neat addition to many toolboxes if you would care to share.
(once it works :) )
caledonian_tartan
Post by caledonian_tartan » 29 Jan 2015, 13:23
that would be cool, FXDUDE!
there is a way to use the view attributes.
i'm about to collect some info. about basic scripting. again. ~x(
I try to point out the steps:
right click on a Node (ICE or Render Tree) --> Should give the name of the selected node : i can create that right click command, but not return the selected node
click on clone (custom command) --> Copy/Paste the selected node and link all parameters to the master : not there yet
this should be VERY easy, but i don't even get around the selection.
even with the help of our promising SDK Explorer.
but shure, if it works, i'll share it like all the stuff i got help on from the forum.
SI 2015 @ WIN7-64
caledonian_tartan
Post by caledonian_tartan » 02 Feb 2015, 12:10
with this JS it is possible to get the selected node in the active render tree.
how can i list its parameters?
this line: "LogMessage( oNode.Parameters );" gives a type mismatch error. why?
// Get Selected Node
// Get the Render Tree view
var oLayout = Application.Desktop.ActiveLayout;
var oRTViews = oLayout.Views.Filter( "Render Tree" );
// Now get the selected nodes
// and log the names of the selected nodes
var x = oRTViews(0);
var a = x.GetAttributeValue( "selection" ).split(",");
LogMessage( a.length );
for ( var i in a )
    var oNode = Dictionary.GetObject( a[i] );
    LogMessage( oNode.Name );
//	LogMessage( oNode.Parameters );
SI 2015 @ WIN7-64
caledonian_tartan
Post by caledonian_tartan » 02 Feb 2015, 12:53
This Python Script goes one step further:
you can log the selected Node in the render tree and
you can log its parameters
a = Application
log = a.LogMessage
### Get The Active View
oLayout = a.Desktop.ActiveLayout
x = oRTViews(0)
y = x.GetAttributeValue( "selection" ).split(",")
### Get The Shader Parameters
a.SelectObj(y, "", "")
oNode = a.Selection(0)
for p in oNode.Parameters:
	log(p)
cool.
next is linking parameter arrays. OMG...
The Main Issue is to filter out Parameters like "Name" or "Mode" which i don't want to clone.
Any chance to just get parameters that are able to be linked by an expression?
(also it seems that - on the diffuse or other color parameters, there are RGB/HLS/HSV values to set)
SI 2015 @ WIN7-64
caledonian_tartan
Post by caledonian_tartan » 03 Mar 2015, 16:47
i finally had some time to work on this.
here it is. a little helper to clone shader nodes.
it works in most cases. sometimes it does not. (Hair_Gradient_Material)
CloneShaderNodePlugin.zip
SI 2015 @ WIN7-64
Post by FXDude » 04 Mar 2015, 00:52
Very nice work (!) and thanks so much for such a nifty handy tool (to say the least)!
Should submit to RRay!
And kudos on overcoming all these obstacles (among probably others)
