I have a character rigged up, and i need to use GATOR to transfer ring/envelope and shape data to other characters.
the characters are very similar and GATOR should do the job, but when i run it it jumps the new character forward....i wounder if anyone knows what i am doing wrong? or if there is a correct procedure to follow to get this thing working?
GATOR issues
opentarget
3DMastermind
Re: GATOR issues
Make sure the centers of the two chars are at the same place.
Manny Papamanos
AD Softimage and MotionBuilder Support Specialist
opentarget
Re: GATOR issues
yep o got this working, the pivots where just a little off and not visible to the eye. all good now.
Victorcg
Re: GATOR issues
Just not to create new thread, I have similar problem with UVs. 2 similar objects, but the UV transfer is ugly! Please help.
Chris_TC
Re: GATOR issues
Try moving one of the objects a tiny tiny little bit before using GATOR.Victorcg wrote:Just not to create new thread, I have similar problem with UVs. 2 similar objects, but the UV transfer is ugly! Please help.
mattmos
Re: GATOR issues
Also with UVs it really helps not to use the smooth surface option but closest vertex, and make sure the preserve property discontinuities is on.
Victorcg
Re: GATOR issues
Thank You, but Your advices don't work for me. Maybe it is some king of tricky mesh, though it is simple gun.
