point position
gigi
point position
i guess this is a simple question, but...how would I get the point position from another cloud? I want to evaluate the distance between 2 points out from 2 different cloud.
burg
Re: point position
Get Data node -> Explorer->Expand the PointCloud->Expand Point Cloud->PointPosition I *Think*
Hope that helps
Burgy
Hope that helps
Burgy
CiaranM
Re: point position
That'll give you the whole data set of points from the other cloud, which you can't use without switching contexts. If the number of points between clouds doesn't match, then switch context won't work. Instead, you need to change that set into an array per point on the current cloud. Here's a quick method:burg wrote:Get Data node -> Explorer->Expand the PointCloud->Expand Point Cloud->PointPosition I *Think*
Burgy
gigi
Re: point position
that wasn't so simple after all
. Thanks a lot!
btw I have subscribed to your online tutorial and i must admit i am still learning a lot from it is...REALLY helpfull. thanks again.
Re: point position
Yeah, the Softimage|ICE-slogan "Code less, create more" comes to mind. In this case it should probably read "Code less, create more nodes"gigi wrote:that wasn't so simple after all
Would be possible for you, CiaranM, to create a compound, so trying to understand it would be slightly easier?
CiaranM
Re: point position
Hey, no problem!gigi wrote:that wasn't so simple after all. Thanks a lot!
Yeah, it's a bit of a pain and can be fraught with problems, trying to get data just the way you want it. This really needs to be improved! But the good thing about ICE is there are so many ways to solve problems like this. Sometimes it's a bit of an adventure, when it should be a walk in the park.Yeah, the Softimage|ICE-slogan "Code less, create more" comes to mind. In this case it should probably read "Code less, create more nodes"
I'll throw together a compound in a few days when I've the time.
gigi
Re: point position
yep... so easy with surface w the <location> coumpound.
I am getting an error at the first ID node when trying to replicate your tree. Looks like a <out of context> thing. I have to agree, a simple scene exemple would be of great help. tks again
gigi
Re: point position
found some time and tested on a simple scene created the simulate>ICE>Create>Emit Particles from Selection way and it's working fine. I guess it wasnt working because i was using plain primitive clouds with no emit node. So I need a <emit from position> in my tree ?..? because of the inti velocity?
anyway... I can now go on having fun with my little experiment.
CiaranM
Re: point position
Ok, here's a little compound that will give you the point position by ID on any input geometry (pointcloud or mesh). It also takes the object's SRT into account.
There would be better ways if you want to deal with the whole data set on the input geo, but this should give you a start.
Get Geo PointPosition
Re: point position
Thanks for the compound...
now I'll just have to find some time to study it...
schyzomaniac
Re: point position
Would you mind posting a link to those? I would like to check them out too.gigi wrote:btw I have subscribed to your online tutorial and i must admit i am still learning a lot from it is...REALLY helpfull.
Thanks,
Daniel
gigi
Re: point position
Thanks for the compound.. I will take a look for sure!
Daniel: you will find Cioran tutorial here : http://www.cmivfx.com
François
François
CiaranM
Re: point position
Nah that's not me!
But if you go there, you will find a really good tutorial series by the very talented Thiago Costa. I recommend you go for it!
gigi
Re: point position
oups ... I guess you are right
ok yeah I was talking about the excellent video from Thiago
.. and thanks for taking the time to help.. really appreciated.
schyzomaniac
Re: point position
Ha!
I already own Thiagos video from cmivfx. ;)
It's really a great training kit. I was hoping there was more in that league available.
cheers,
Daniel
cheers,
Daniel
