Some animals
Comments on finished work
Pancho
Some animals
Post by Pancho » 01 Oct 2014, 20:06
Hi there,
I recently finished a small campaign for synthetic fur bags.
No animals were harmed in the production of the these bags, so even animals would buy/pose with them. That’s the idea behind it.
Technically I used SI. No big secrets. Rigging was done by Georg Schneider, the rest by myself. The hair has been created with my own fur system, using strands in ICE.Contrary to MR, RS worked like charm even/especially with GI enabled. Inpossible in MR.
About 20-40m before it actually started to render, but then it took only about 1h to render 8x6k (Titan Black). Fantastic!
Since I created the fur system by myself. I could take care of intersections of the strands with the actual geometry. So no bald patches which needed retouching. Using Modo or LW in the past, this was one of the biggest issues with their fur solutions. Especially with flat, wild hair.
So in the end, apart from minor retouching and brightness changes, very little post production.
Thomas
Re: Some animals
Post by FXDude » 02 Oct 2014, 03:31
'Some animals' indeed!!!
So you're saying that you basically used your own (furry) features to make your subjects so lifelike?
Man! Softimage is what again? dead you say?
I think it's as alive as what made those creatures look so alive :]
Re: Some animals
Post by Bullit » 02 Oct 2014, 05:04
Make my words the FxDude ones.
Add this should be in Great Softimage Work.
Edit: how do you render tested to get the correct look?
Pancho
Re: Some animals
Post by Pancho » 02 Oct 2014, 07:24
The correct look for the fur?
julius
Re: Some animals
Post by julius » 02 Oct 2014, 09:16
Fantastic !
Skype: ondraise
Re: Some animals
Post by Draise » 02 Oct 2014, 16:58
Wow that cheetah.
Great work! And amazing work on the custom fur!
Re: Some animals
Post by Bullit » 02 Oct 2014, 19:46
For the whole scene but specifically the fur.
xsi_fanatic
Re: Some animals
Post by xsi_fanatic » 02 Oct 2014, 20:23
Amazing work ! :D
Is this for a commercial product ?
iamVFX
Re: Some animals
Post by iamVFX » 04 Oct 2014, 14:19
Can you make a naked human with a purse from human skin too?
milanvasek
Re: Some animals
Post by milanvasek » 09 Oct 2014, 12:39
this is really nice! great hair
Milan Vasek
ceramic artist & softimage fan
http://www.milanvasek.com
druitre
Re: Some animals
Post by druitre » 10 Oct 2014, 11:48
Hey Thomas, brilliant!
Re: Some animals
Post by Hirazi Blue » 10 Oct 2014, 15:26
@Pancho - What specifically did you want to address when you set out to build your own fur system?
Re: Some animals
Post by Bullit » 11 Oct 2014, 15:28
That is a very good question.
bb3d
Re: Some animals
Post by bb3d » 11 Oct 2014, 22:31
Wow, awesome job, I am impressed! ^:)^
Pancho
Re: Some animals
Post by Pancho » 13 Oct 2014, 09:33
After working with LW and Modo fur I was pretty much fed up with all those limitations and not knowing what's going on under the hood. Especially flat fur without interpenetration isn't possible with both software packages. And while SI might be able to comb guide hair ON the mesh, I'm not sure whether the strands generated afterwards would behave in the same way. With my fur system I can take care of this.
I also have the ability to change the order of the styling. Depending on what you want to achieve this will make a big difference. So, in the end I've got pretty much all the freedom I need, while it might be a bit slower, since it is fully made in ICE.
Re: Some animals
Post by Hirazi Blue » 13 Oct 2014, 19:12
Thanks for the clarification! ;)
